Results 1 to 10 of 20
Thread: What`s the DIFFS
    May 2020
    JOHANNESBURG
    What`s the DIFFS
    So as a matter of opinion, i want look into replacing the diff with the V6 unit. Drums vs Discs.
    can this be done if the ratios are the same? as we have spare yards here and theres afew V6`s looking sad.
    Nov 2007
    Can't tell you about the diffs I'm afraid. I have looked into the gear ratios and especially the final drive ratio of the TSI vs the TDIs.
    2013 Amarok ratios (from VW brochure)
    What`s the DIFFS-2013-amarok-gear-ratios-jpg
    2020 Amarok 2.0TDI ratios (from VW brochure)
    What`s the DIFFS-amarok-tdi-gear-ratios-png
    2020 Amarok V6 ratios (from VW brochure)
    What`s the DIFFS-amarok-v6-gear-ratios-png
    The good news (from my perspective) is that the TSI and TDI ratios are pretty close. I will be attempting a AWD manual transplant from a BiTDI to the TSI at some point in the future.
    Pity that they don't publish the final drive ratio of the V6 is that will give you some indication as to the diff's ratio compared to the 2.0 TDIs
    I'd be looking at ETKA or similar for detailed info for the diff ratios though.
    Adelaide hills, SA
    ...or the spare parts and see if the crown and pinion have the same amount of teeth.
    Sent from my iPhone using Tapatalk Pro
    May 2020
    JOHANNESBURG
    Thanks guys, I will look into this a bit more. might even look to upgrade front brake setup
    Nov 2018
    Dubbo NSW
    You would be best to go with a manual 120kw/400nm diff, the auto diff is too tall for in 6th gear unless your doing 110kph+ and not too hilly. The lower gears aren't too bad but its not ideal at any point really. the 4.1's from the manual 400nm utes would be ideal as you get to load the turbo up a little more and you get a slightly better hwy cruising rpm.
    Nov 2018
    Dubbo NSW
    the auto diff will also throw out your digital gear indicator and the cruise won't work in 6th gear as the car doesn't recognise the gears properly. Having a play with the speedo/wheel size options in the VCDS may overcome this though.
    Apr 2021
    On the topic of Amarok diffs, was wondering if anyone knew how the Amarok rear diff lock system works? Is it just an electronic brake actuated style or a true mechanical lockable diff center?
    2013 TSI300 2wd I just purchased wasn't optioned with a rear diff lock and I was hoping I could add this now.
    Nov 2007
    I have it and believe it is a mechanical lock. That is how it was sold to me and I can confirm that locking it and using the power from standstill will leave 2 black lines on the road ..... I don't think the electronic diffs can do that
    Apr 2021
    Haha nice!! Using that TSI APR power
    May 2020
    JOHANNESBURG
    Quote Originally Posted by EZZA View Post
    I so need to find a sponsor for my APR, dying to unleash my TSI, wonder on the S/C how tail happy it will be. ANY takers
